Hi There,
I am wanting to combine 3 different 28V supplies into one 22V supply, sharing current between all of the upstream supplies.
The LT8637 looks good in that it supports sharing between two modules, but I have three followup questions:
- Does this work if the input supplies are not common?
- Can this be extended to 3 converters in parallel?
- To facilitate #2, would it be acceptible to phase the clocks differently using delay lines (or some other way) between the converters to achieve balanced phase differences, not just 180deg.
David
