I'm a DFAE in Japan. Our customer doesn't understand the spec difference between LTC3309BJ and LTC3309BH. Could you help us the answer?
Hiroyuki
LTC3309B
Recommended for New Designs
The LTC3309B is a very small, high efficiency, low noise, monolithic synchronous 6A step-down DC/DC converter operating from a 2.25V to 5.5V input supply...
Datasheet
LTC3309B on Analog.com
Hiroyuki
LT parts which have a letter behind their number code (like A, B or C) are pin compatible. The changes mostly just offer improvements and/or more robust operation compared to the 'older' part.
Nino
Thank you very much for your reply. But I'd like to know the difference between BJ and BH instead of A and B.
Hiroyuki
My explanation same goes with H & J. The J part probably offer improvements on the manufacture side and/or more robust operation compared to the 'older' part which is the H part. You can still choose either part since they still have the same operating temperature and operation.
Nino
