Burning issue of LTC3600
Product Number: LTC3600
My customer is testing LTC3600 for applying their system and now they got some issues.
At their system, Vin is fixed at +15V and  ISET is controled by output pf gain amp. with 0 to +15V range.
For this, they got 3A  output  at Vout. ( They use 2 LTC3600 and current sharing.)
When they supplu +15V at Iset pin, LTC3600 is burned.
Please refer below questions and attached their schematic.
Q1) Would your confirm below their schematic?
Q2) Would you suggest the reason why LTC2600 is burned?
Q3) Would you suggest how to solve this issue?
Please let me know your opinions.
I need your help.
Se-woong
Parents
  • Hello,
    • is there no capacitance at VIn?
    • What kind of capacitance is installed at VIN?
    • 15V Vin are the max operating, has your customer tried a smaller input voltage for test purpose?
    • You have only 1V margin to absmax of 16V
    • How is the 15V input supplied? Step function with steep edges or slow ramp up?
      /www.analog.com/.../an88f.pdf
    • How is RUN and VIN voltage supplied and with which timing/delay?
    • Is full current of 3A demand at start-up?
    Check the circuit with smaller Vin first to see if part still fails
  • Dear MarkusHP
    Thank you for your kind help.
    Please refer below answers for your questions.
     - VIN is connected to +15VE of system power and connected like picture.
    - They should get variable output power between 0.5V and 13.5V, so VIN should fix +15VE.
    - VIN is supplied at the same time  when system power is on.
    - RUN is supplied when they are needed, not always. (Not the same time)
    -  Spec. of their system  should supply 3A (Max. current of  LTC3600).
    - They need max.3A current.
    - If output power is varied from 0.5V to 12V, up and down of output power is operated normally without any problem.
    -  Issue is when output power is approched at about 13V, LTC3600 is malfunctio and device is burned.
    I hope this help.
    Se-woong
  • Dear MarkusHP
    Please confirm their answers in above messsage  and let me know your opinons.
    My customer is still waiting your help.
    Se-woong
  • Dear MarkusHP
    Would you let me know your statue about this issue?
    Se-woong
  • Have you ever simulated the schematic in LTSpice and check the power losses at higher Pout?
    What is the temp of the parts with smaller VIN and still operating(related to output power)? have you ever checked that?
    And I'm just a regular FAE like you, hence my customer prevent me to serve as full time source in EZ, sorry.
  • Dear MarkusHP
    And I understand your status.
    Finally , my customer change the device from LTC3600 to LTC3263 with supporting more current.
    Se-woong
Reply Children
No Data
