On LTM4630 (and others, will tag below), is the CLKOUT active when the RUN1 and RUN2 pin are low? Does the CLKOUT become active when _either_ run pin is true?
LTM4630A
Recommended for New Designs
The LTM4630A is a dual 18A or single 36A output switching
mode step-down DC/DC µModule® (micromodule)
regulator with wider VOUT range and higher efficiency...
Datasheet
LTM4630A on Analog.com
LTM4620
Production
The LTM4620 is a complete dual 13A output switching mode DC/DC power supply. Included in the package are the switching controller, power FETs, inductors...
Datasheet
LTM4620 on Analog.com
LTM4620A
Production
The LTM4620A is a complete dual 13A, or single 26A output switching mode DC/DC power supply with wider VOUT range and higher efficiency than the LTM4620...
Datasheet
LTM4620A on Analog.com
Hello Jake,
It looks like the CLKOUT pin status is not dependent on the RUN pin of the part, so when not in used you can leave it floating. It is only affected depending on the MODE_PLLIN and PHASMD pins.
Nino
Ok, thanks. The LTSPICE model (as of 11/21/22) does not agree:
