LTM8055 Parallel Operation
Product Number: LTM8055, LTC6909
I am trying to make a circuit configuration using LTM8055.
I would like to configure as many LTM8055s as possible in parallel.
Question 1. Can you tell me how many LTM8055 can be configured in parallel?
I need to configure input 28V, output 28V 35A.
Previously I configured the LTC6902 with 4 LTM8055s in parallel.
If you use LTC6909 (8phase), you can configure up to 8 LTM8055.
Question 2. Can you tell me if it is possible to parallelize up to 8 LTM8055s using the LTC6909?
질문 2. LTC6909를 사용하여 최대 8개의 LTM8055를 병렬화할 수 있는지 알려주실 수 있습니까?
Question 1. Can you tell me how many LTM8055 can be configured in parallel? Question 2. Can you tell me if it is possible to parallelize up to 8 LTM8055s using the LTC6909?
[edited by: Frankie.Jeon at 8:38 AM (GMT -4) on 31 Oct 2022]
Parents
  • FormerMember
    0 FormerMember
The datasheet only provides up to two LTM8055 configured in parallel. It is on page 20 LTM8055 (Rev 0) (analog.com).
It should be possbile as there is a clock/sync pin for LTM8055. I have seen the LTC6909 and it should be straightforward.
Refer to page 17 of the datasheet LTC6909 - 1 to 8 Output, Multiphase Silicon Oscillator with Spread Spectrum Modulation (analog.com) for the example.
Reply
  • FormerMember
    0 FormerMember
Children
No Data
