Negative output Voltage
Product Number: LTC1624
I found a component that may be suitable for my application the LTC1624 (please see the DS in this attached). I don't understand very well how it works this electronic assembly :
Is it possible to delete M2/M3 and R3 to have something simpler. I have only +12V (comes from the battery voltage) and I need -5V with 1A to the ouput. Thank you for your helps.
Regards
Yann DOPDF
on Oct 26, 2022 7:58 PM
You can use this schematic and adjust accordingly to satisfy your specification.
  • FormerMember
    0 FormerMember on Oct 26, 2022 7:58 PM in reply to 206_RC
    You would need to find and import the spice model for the component.
  • After working under LTpowerCAD I lost all the schematics of the simulation. Can I work with LTspice (that I know a little better). ? I think it's the same unless I am mistaken.
    Under Mouser I can see 2 models for this component, I think  I must take the second model  Spice2 Model for 'MBRS340T3' and not PSpice I suppose ?
    Do you have links or information to import components under LTspice for simulation ? Thank you for your feedback
    Regard
  • Thank you this diagram will be very useful to me but I will need -5V and not +5V and do you know the method to ajust the current to +1A instead of +2A like your schematic ?
    Regards
    After drawing the circuit I don't get -5V but -6V.
     Something is wrong but I don't know where. But after the DS normally I'll have -5V with a supply +12V
    I just removed the following components : M3/M2/R3 and Shutdown. Do you have a idea where is my mistake ? Please see in this attached my simulation.
    PJ LTC1624.zip
  • Thank you Jhun,
    But my goal is to find a to find a circuit with a negative voltage at the output (-5V). Do you how  I guess I have to calculate the component values ​​to get the -5V. I found this electronic assembly but it is enough that I adapt a little to find the -5V right ?
    Regards
  • FormerMember
    0 FormerMember on Oct 28, 2022 3:36 AM in reply to 206_RC
    That is a negative output.
    In the schematic,
    The referenced ground is the VNEG output.
    The circuit I sent is an alternative as to how to generate a negative output from a buck controller in the simulation.
  • The referenced ground is the VNEG output.
    Sorry but I can't see the VNEG output in your schematic. Where it's (sorry I'm a beginner under LTspice).
    Where must I take my probe to see the negative voltage ?
