I want to simulate LTM8001 in powercad design software. the said part is not available. how to add new parts please guide.
LTM8001
Recommended for New Designs
The LTM8001 is a 36VIN, 5A step-down µModule® regulator with a 5-output configurable LDO array. Operating over an input voltage range of 6V to 36V, the...
Datasheet
LTM8001 on Analog.com
Hi Naga9999,
Currently it is still not available in LT Power CAD. Please contact local FAE to help you with it. I suggest that you follow the design procedure on the datasheet and try to simulate it in LTSpice where it has an available model.
If you can give me your project information and estimated annual usage (EAU), I can help connect you to a local FAE. Thanks.
Nino
Ltm8001-100 units, ltc3260- 100 units
Quantity required.
Having issues with its modelling in powercad for power management analysis.
5 output ldo with negative and positive voltages is the requirement.
It will be better if u share local FAE contact details.
Thanks.
