The question is in title ... is ADP5600 capable provide -40V on its CPOUT output (input is +5V) ?
Also does exist a model for LTSpice ?
Thanks.
Sincerely,
Pavel.
ADP5600
Recommended for New Designs
The ADP5600 is an interleaved charge pump inverter with an integrated, negative, low dropout (LDO) linear regulator. The interleaved charge pump inverter...
Datasheet
ADP5600 on Analog.com
Thanks.
Sincerely,
Pavel.
Hello Pavel,
The CPOUT output pin can only handle a maximum of -20V based on the Absolute Maximum Ratings from the datasheet.
Nino
Hello Pavel,
Nino
