LTC9101-1
Recommended for New Designs
The LTC9101-1/LTC9102/LTC9103 chipset is a 48-port power sourcing equipment (PSE) controller designed for use in IEEE 802.3at Type 2, 802.3bt Type 3 and...
Datasheet
LTC9101-1 on Analog.com
Dear Sir
We observous the LTC9101-1/LTC9102/LTC9103 has Proprietary Isolation Scheme .
Does it have any other scheme replae it ? (reference using Transformer between LTC9101 and LTC9102)
on our desing we need to reserve isolation between System to LTC9101 in order to meet spec
thanks
The communication between the LTC9101-1 and LTC9102s/LTC9103s is through a high-speed data interface over either a proprietary isolation scheme or direct connection scheme.
In the proprietary isolation scheme, the LTC9101-1/LTC9102/ LTC9103 chipset uses transformers to isolate the LTC9101-1 from one to four LTC9102s/LTC9103s. The transformers should be 10BASE-T or 10/100BASE-T with a 1:1 turns ratio. These transformers typically provide 1500V of isolation between the LTC9101-1 and the LTC9102s/LTC9103s. Optimally, the selected transformers do not have common-mode chokes. If a transformer with chokes must be used, the chokes should be on the LTC9102/LTC9103 side of the isolation. Refer to the figure below.
In the direct connection scheme, the LTC9101-1/LTC9102/LTC9103 chipset relies on pre-existing system isolation. In this scheme, the LTC9101-1 connects directly to one to four LTC9102s/LTC9103s using a proprietary communication protocol. Refer to the figure below.
Best Regards,
Eric
Best Regards,
Eric
Dear Eric
Thank you for the information.
Brian
