LT1170
Production
The LT1170/LT1171/LT1172 are monolithic high power-switching regulators. They can be operated in all standard switching configurations including buck,...
Datasheet
LT1170 on Analog.com
LT1170_TA01_buckboost.ascHello, On page 14 of the LT1170 datasheet there is a note for the inverting buck boost converter that allows you to change the output from -12V to -5V with three component choices. When I simulate this circuit in ltspice with the component choices I still see the output of the regulator at -12V. Could you make a suggestion that would allow me to change the output of this regulator to -5V ?
Hello lightelligencespencer,
Referring from the Figure on page 14 of the datasheet, Output voltage is set by the ratio of R1 to R2. R3 and C2 provides frequency compensation.
Kindly refer to the Application Note 19 — LT1070 Design Manual. This manual contains a comprehensive discussion of the LT1070 and the external components as well as the complete formulas for calculating the values of these components. The manual can also be used for the LT1170.
AN19 - LT1070 Design Manual (analog.com)
I also attached below a sample inverting buck-boost circuit which outputs -5V.
Nino
Hi Nino, Thanks for your helpful answer! Much appreciated.
Hi Nino, When running a load step for the spice simulation you provided, I don't find that the regulator is maintaining the output voltage under high load. Could you help me understand what I might be doing wrong? Thanks.LT1170_buckboost_ninoADI_loadstep.asc
