LTM8042
Production
The LTM8042 is a complete µModule® (power module) Boost LED Driver specifically designed to drive LEDs up to 1A, while the LTM8042-1 drives up to 350mA...
Datasheet
LTM8042 on Analog.com
Regarding the LTM8042 PWM dimming: When the PWM dimming signal goes from LOW to HIGH, how long does it take the LED Current to reach its 100% of its setting? Also how long does the turn off time take from when PWM goes from HIGH to LOW for to reach 0% output current?
Hello KevinL,
You may refer from the page 17 of the datasheet regarding the PWM Dimming control of LTM8042. This part also has an available LTSpice model and demo circuits so you can confirm depending on your application.
Nino
