We are designing a battery charging system with the LTC4020 for a 3A max charge and 20A max discharge. In order to save space and lower potential losses, can a Schottky diode be added in parallel with the PowerPath FET?
Thank you.
LTC4020
Recommended for New Designs
The LTC4020 is a high voltage power manager providing PowerPath™ instant-on operation and high efficiency battery charging over a wide voltage range. An...
Datasheet
LTC4020 on Analog.com
Thank you.
Hi @mzilvetti,
Upon consulting the device experts,
It is assumed that the Schottky diode is for conducting the 20A discharge current. I don’t see a problem with this. Note that the discharge current will be shared between the PowerPath FET and the added Schottky diode. The current going through the PowerPath FET will be Vf/Rds-on, where Vf is the forward voltage drop of the Schottky and Rds-on is the on-state resistance of the PowerPath FET.
Hope this helps.
Noel
Hi @mzilvetti,
Hope this helps.
Noel
