I connect SHDN pin to 2UPU pin to shutdown the load switch as mentioned in datasheet but it didn't work(N-Mosfet still turn ON), please clarify about this function.
LTC4372
Recommended for New Designs
The LTC4372/LTC4373 are positive high voltage ideal diode controllers that drive an external N-channel MOSFET to replace a Schottky diode. They control...
Datasheet
LTC4372 on Analog.com
Refer below,
You should be pulling the SHDN pin above 1.215V.
Refer below,
