LT3013 SHDN does not work
Product Number: LT3013
The SHDN pin does not work. When I pull EN pin to ground, LT3013 still produces the output voltage. I checked voltage on SHDN pin is 0V when pull the pin low. I replaced the IC with a new one and the issue still continues. What could be the reasons ?
Thanks in advance.
EDIT : I've created a new board which only contains LT3013 and the same issue has happened again. The IC does not turn off. Here is the schematic.
Edit Notes
New trials
[edited by: FrequencyModulator at 1:19 PM (GMT -4) on 12 Sep 2022]
