Is there any noise data available for the LT1185?
A noise spectral density plot would be nice.
Thanks!
LT1185
Production
The LT1185 is a 3A low dropout regulator with adjustable current limit and remote sense capability. It can be used as a positive output regulator with...
Datasheet
LT1185 on Analog.com
Thanks!
I Inserted an NSD plot and uploaded my spreadsheet with setup and schematic.
Thank you very much!
I assume at 18V the noise would be 3.6 times the 5V noise.
And with a capacitor across the feedback resistor, the noise should become about half of the one you measured above frequencies where the capacitor's impedance becomes much lower than 2.37k, right?
(The fall off of the noise above 100kHz is assumed to be due to the low pass filter formed by the output resistance of the regulator (about 1 ohm) and the 2µF capacitor.)
