Is there any contraindications about the use of 3 x LTC4444 as gates driver for a full bridge inverter on a 28V (500W approx) BLDC motor application?
I can't find any references about the use of LTC4444 on motor applications.
Thanks
LTC4444
Production
The LTC4444 is a high frequency high voltage gate driver that drives two N-channel MOSFETs in a synchronous DC/DC converter with supply voltages up to...
Datasheet
LTC4444 on Analog.com
Thanks
Hi BestUser,
Apologies for late response. Looking at the datasheet, this product is designed to be used for DC/DC converter applications. I am not sure if it is advisable to use for full bridge applications.
Hi BestUser,
i also noticed from the datasheet that this is a DC-DC gate driver but this is the only gate driver with a -55°c operative temeperature i found. It seems almost impossible to find a gate driver with such low temp range. Could we have more informations to confirm that LTC4444 is completely to avoid for a full bridge inverter application? Or, could you suggest any other gate driver with -55 operative temp?
Thanks
Regards
The LTC4444 does not contain a charge pump (for example, like the 100% duty LTC7001) and therefore requires a diode (from VCC to BOOST) and TS to pull to ground periodically to refresh the BOOST-TS capacitor. If this is acceptable in your application, then the LTC4444 may be a good choice.
