I want to minimize the rise of the FB terminal that occurs after Optimum Power Search. What is the method?
The attached figure is a figure of the manual of DC2330A Demo Board.
The part surrounded by the red frame is the rise in FB voltage.
LTC4125
Recommended for New Designs
The LTC4125 is a simple and high performance monolithic full bridge resonant driver capable of delivering over 5W of power wirelessly to a properly tuned...
Datasheet
LTC4125 on Analog.com
Hi Dachin,
The high FB rise is normal and it is designed to be like that so it is easy for LTC4125 to hit the exit condition of the optimum power search. However, if you would like to lower the FB rise, you can reduce the rated voltage for the zener diode (D4, on page 14 of the DC2330A demo manual) in the presence detect circuit.
Wenwei.
Hi Wenwei
I understand that the rise in FB voltage is the correct operation. I evaluate the change in FB voltage when the rated voltage of the Zener diode(D4) is changed.
Thank you.
Dachin.
Hi Wenwei
Thank you.
Dachin.
