Hi Sir,
If increase PCB soldered to 5000mm2 and four-layers 2oz, the DFN package's thermal resistance will approximately how much °C/W?
Thanks.
LTC4425
Recommended for New Designs
The LTC4425 is a constant-current/constant-voltage linear charger designed to charge a 2-cell supercap stack from either a Li-Ion/Polymer battery, a USB...
Datasheet
LTC4425 on Analog.com
Hi Sir,
Thanks.
I think a thermal simulator would be needed with the copper thickness and dimensions, thermal vias in the EPAD used, connecting copper to inner layer thickness and dimensions.
Please take this with grain of salt. Best is still to run simulation as to how much reduction is achieved by doubling the copper area.Below is copper size change of ADP7118 LDO as seen in datasheet. Thermal resistance of LFCSP is reduced by ~10C/W from 500 to 1000mm copper area.
