LTC3888 in LTpowerCAD
Product Number: LTC3888
I'm a DFAE in Japan. Our customer would like to select optimum values for type 2 compensation of LTC3888. However we can't see LTC3888 in LTpowerCAD. Is it not available? If not, please tell me an alternative method.
Hiroyuki
Top Replies
  • FormerMember
    FormerMember
Jun 15, 2022 +2 verified
As LTC3888 is uses OTA as its compensation, you can use controllers that also use that. But the thing is that the LTC3888 has a programmable internal error amplifier. Maybe you can try using the…
Parents
  • FormerMember
    +1 FormerMember
on Jun 15, 2022 7:50 PM
As LTC3888 is uses OTA as its compensation, you can use controllers that also use that. But the thing is that the LTC3888 has a programmable internal error amplifier. Maybe you can try using the LTC3871 but it would not be accurate. My advice is that have a predefined value and get a bode plot, and then adjust from there. The datasheet has some information about the loop compensation.
Jhun
Reply
  • FormerMember
    +1 FormerMember
Jhun
Children
No Data
