LTC4364
Recommended for New Designs
The LTC4364 surge stopper with ideal diode controller protects loads from high voltage transients. It limits and regulates the output during an overvoltage...
Datasheet
LTC4364 on Analog.com
Hi hamed,
Apologies for late response. Even without load, output capacitors may still cause inrush current to the FET. Issue could still be SOA. You may also double check if you are following layout guidelines. You may check waveforms using oscilloscope to better understand when the failure happens.
I would also suggest contacting a local FAE to have a deeper look on this issue. You can also submit a support ticket through here: Technical Support Form | Analog Devices
