ADP1614 SW pin Maximum Negative Voltage
What is the maximum negative voltage the SW pin can sustain?
Datasheet only states "21V" while all other pins have a voltage range, not a single value.  SW pin can usually sustain some negative voltage.
I have some undershoot at turn on.  Worst case is -2V .
Not good, not bad but I can't tell if it's acceptable for the part.
Please advise.
Regards
Frederic
