ADP5350 battery charging issue
Result from our charge test shows that battery level increases linearly during the charge.
See the image below for charge graph:
- X axis is time in hour.
- Battery level is read from ADP5350 chip.
Schematic
Configuration
Register Name Address Value Register Name Address Value
Manufacture and model ID 0x00 0x1B K_RBAT_CHARGE 0x1F 0x01
Silicon revision 0x01 0x03 BAT_TEMP 0x20 0x5B
CHARGER_VBUS_ILIM 0x02 0x0A BAT_SOC 0x21 0x09
CHARGER_TERMINATION_SETTINGS 0x03 0xAC VBAT_READ_H 0x22 0x83
CHARGER_CURRENT_SETTING 0x04 0x3E VBAT_READ_L 0x23 0xF8
CHARGER_VOLTAGE_THRESHOLD 0x05 0x5B FUEL_GAUGE_MODE 0x24 0x01
CHARGER_TIMER_SETTING 0x06 0x78 SOC_RESET 0x25 0x00
CHARGER_FUNCTION_SETTING1 0x07 0xCF BST_LED_CTRL 0x26 0x1C
CHARGER_STATUS1 0x08 0x02 BST_CFG 0x27 0x00
CHARGER_STATUS2 0x09 0xE4 IBL_SET 0x28 0x00
CHARGER_FAULT 0x0A 0x00 ILED2_SET 0x29 0x00
BATTERY_SHORT 0x0B 0x45 ILED3_SET 0x2A 0x00
BATTERY_THERMISTOR_CONTROL 0x0C 0x38 ILED4_SET 0x2B 0x00
V_SOC_0 0x0D 0x6B ILED5_SET 0x2C 0x06
V_SOC_5 0x0E 0x8E BL_FR 0x2D 0xDD
V_SOC_11 0x0F 0x92 LED3_BLINK 0x2E 0xB4
V_SOC_19 0x10 0x97 LED4_Blink 0x2F 0xB4
V_SOC_28 0x11 0x9A LED5_Blink 0x30 0xB4
V_SOC_41 0x12 0xA4 LED_STATUS 0x31 0x00
V_SOC_55 0x13 0xAE LDO_CTRL 0x32 0x07
V_SOC_69 0x14 0xB8 LDO_CFG 0x33 0x00
V_SOC_84 0x15 0xCE VID_LDO12 0x34 0x92
V_SOC_100 0x16 0xD4 VID_LDO3 0x35 0x02
FILTER_SETTING1 0x17 0x44 PGOOD_STATUS 0x36 0x0D
FILTER_SETTING2 0x18 0x00 PGOOD_MASK 0x37 0x08
RBAT_0 0x19 0x3F CHARGER_INTERRUPT_ENABLE 0x38 0x00
RBAT_10 0x1A 0x3F CHARGER_INTERRUPT_FLAG 0x39 0x00
RBAT_20 0x1B 0x3F BOOST_LDO_INTERRUPT_ENABLE 0x3A 0x00
RBAT_30 0x1C 0x3F BOOST_LDO_INTERRUPT_FLAG 0x3B 0x00
RBAT_40 0x1D 0x3F DEFAULT_SET 0x3C 0x00
RBAT_60 0x1E 0x3F NTC47K_SET 0x3D 0x01
Battery profile
/cfs-file/__key/communityserver-discussions-components-files/330/PCNV553037_2D00_750mAh-1-_2D00_-en.xlsx
/cfs-file/__key/communityserver-discussions-components-files/330/PCNV553037_2D00_750mAh-2-_2D00_-en.xlsx
Please help to check whether I am using the chip correctly.
Thanks.
