is now a LT Power CAD model available for the part LTC3372?
regards
Martin
LTC3372
Recommended for New Designs
The LTC3372 is a highly flexible multioutput power supply IC. The device includes a high-performance, high voltage (HV) step-down DC/DC switching regulator...
Datasheet
LTC3372 on Analog.com
regards
Martin
Hi Martin,
Currently it is still not available in LT Power CAD. I suggest that you follow the design procedure on the datasheet and try to simulate it in LTSpice where it has an available model.
Jhun
Hi, thanks, what is the nearest part to do calculations for the compensation (bode plot) in LT Power CAD, e.g. LTC3891 or would you recommend another one? Regards Martin
Hi Martin,
Yes you can use LTC3891 for the compensation. However, this will not be accurate when testing on the real board. Compensation values on the datasheet in page 37 is a good starting point. Hope this helps. Thank you.
Jhun
