Using ADP5303-1 When switching mode to PWM mode and holding mode high the regulator appears to lock up and go into a precharged startup. This in turn causes a lockup as the Microcontroller holds mode High and the voltage oscillates around the mode enable state. Sync/mode is being driven similar to Figure 36 of datasheet and setup is as figure 43 of the datasheet.
