Hi ADIExpert
May I Know if LT8309 can be a drop in replacement solution to replace FAN6240 as the application diagram below from DS of it
www.farnell.com/.../2286089.pdf
the output Voltage of customer's application is 30V.
in such case, I think the rectifier that shown in the DS of LT8309 can be removed and is able to connect VCC to the Vout node directly
just kindly need your advice that is there anything I overlooked that may make the replacement doesn't work?
thanks
Ken
