I'm in trouble...
About current detection accuracy of FBP, FBN terminal,
Please tell me about the error of the voltage between FBP and FBN terminals.
I would like the following information.
・ Inspection specifications (Vfbp-Vfbn inspection upper and lower limits)
・min / max value of Vfbp-Vfbn
→ Also, if a value that is significantly different from this value is measured, is it a judgment that the IC has failed?
・ Design value and calculation value of variation
→ How does this error(Vfbp-Vfbn) affect the calculation formula on the datasheet?
We would appreciate it if you could tell us more information than the following datasheet contents.
www.analog.com/.../j3783fb.pdf
Best Regards,
Naohisa
