LTM4622 & LTM4622A output voltage range
I'm having a specific question regarding the output voltage range  of the said parts. According the datasheet :
LTM4622 output voltage range can go from 0.6 to 5.5V
LTM4622A output voltage range can go from 1.5 to 12V
My issue is that I used a LTM4622A by mistake to provide a power rail below its minimum output voltage (0.9V & 1.09V)  and didn't get any
problems using after numerous power cycle and a load that can go up to 600mA.
Is there any explanation to this, and most importantly, could it lead to failure and reduce its life cycle by a fair margin ?
Kind Regards
