Is it OK to use the LT1084 as a current regulator in the following way?
The current value is determined by resistor R1, and it worked fine in LTspice.
Thank you very much for your help.
Kazu
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LT1084
Production
The LT1083/LT1084/LT1085 series of positive adjustable regulators are designed to provide 7.5A, 5A and 3A with higher efficiency than currently available...
Datasheet
LT1084 on Analog.com
Kazu
Could you please take care of this case?
Kazu
I don't have a problem with your circuit. It is possible that the actual hardware may need some capacitance for stability. Usually you test the stability of these current regulator circuits by doing a line transient and making sure the current does not ring too much.
I'm thinking of making a 10A constant current circuit with two LT1084s connected in parallel.
The circuit and simulation waveforms are attached.
Is there any problem? Please advice me if anything I'm missing.
Kazu
Hi
Please reply to my question about the above 10A constant current circuit.
Kazu
