Our design uses LTC4212 for 3.3V ORing.
Current Rating: 4A (max)
Following MOSFET has been chosen for the design: Si6423ADQ / Vishay
Pl let us know if this MOSFET is good enough for the application?
Best Regards,
Pons
LTC4412
Recommended for New Designs
The LTC4412 controls an external P-channel MOSFET to create a near ideal diode function for power switchover or load sharing. This permits highly efficient...
Datasheet
LTC4412 on Analog.com
LTC4212
Production
The LTC4212 is a Hot Swap™ controller that allows a board to be safely inserted and removed from a live backplane. An internal high side switch driver...
Datasheet
LTC4212 on Analog.com
Best Regards,
Pons
Are you sure that you have the right part numbers?
The LTC4212 is a Hot Swap controller that requires an N channel MOSFET.
The Si6423ADQ is a P Channel MOSFET
JayBee
Hi JayBee,
Apologies for the wrong PN. Correct PN is: LTC4412.
- Pons
Pons,
Based on this graph from the MOSFET datasheet:
And the RDSon, the Si6423adq is a suitable MOSFET.
The forward voltage drop of the ideal diode will be around 60mV.
JayBee
Thanks JayBee for the analysis & confirmation.
- Pons
