CAN I use two LTM4644 to make 32A ? If yes, need I tie all FB, track,COM and Vout pins together? And need I tie ClockOUT pin of first LTM4644 to theClockIN pin of the second LTM4644???ThankS
Yes you can. You can tie the CLKOUT of the first module to the CLKIN of the second module. The FB, TRACK, RUN, COMP and Vout should be tied together. You can refer to this answer:
