Vsense- pin connection
 As per datasheet of ADM1270 hotswap controller, the VSense-  pin should be connected to drain of the FET.
But in the eval schematics of the ADM1270, this pin is conencted to the source of a p-channel FET.
Also, the foldback pin no 11, in datasheet mentioned as to connect with source of the FET.
But in eval schemtics FLB pin resistor divider is connected to drain of the FET.
Could you please confirm which is correct connection to these pins.
Thanks & regards,
Reshma,
HCL Technologies,
India.
