LTC7871 or similar: Higher voltages
Is there anything similar to the LTC7871/72 that can handle higher Vhigh voltages? I am trying to find a solution to boost the Vhigh voltage to about 120V.
  • Hello Diesel,
    The LTC7871/2 could be used for a 120V boost. However, these requirements should be met:
    • VHIGH pin of the LTC7871/2 needs to be connected to a supply voltage less than 100V. Keep the voltage on VHIGH or EXTVCC low enough to avoid excessive power losses in the respective LDOs.
    • A three-state compatible gate driver with a SW rating equal to or greater than 120V * 1.2 should be used where 1.2 is a safety factor. We do not have a three-state compatible gate driver with a sufficient rating at the moment.
    Contact your local sales office for more support. Or contact me directly at michael.shriver@analog.com
    Mike
