LTC3225 Total Current Consumption
I am connecting 100K ohm resistor at RPROG to set the charging current to 36mA. The SuperCap output is set to 4V. The LTC3225 is powered from +3.3V supply.  I would like to find out the total input current consumption.  I understand that internally the LTC3225 use the Charge Pump to increase the voltage to 4V.  If the charging current is set to 36mA, does it means the output is 4V 36mA?
