Hello
Customer use LTC4373 EVM for 12V/8V o-ring application. If they would like to add external diode D5A. Have any suggest RC snubber value to testing? Thank you.
BR
Patrick
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LTC4373
Recommended for New Designs
The LTC4372/LTC4373 are positive high voltage ideal diode controllers that drive an external N-channel MOSFET to replace a Schottky diode. They control...
Datasheet
LTC4373 on Analog.com
Hello
BR
Patrick
Hi Patrick,
Snubber may not always be needed but when needed, it is experimentally determined to suppress ringing or oscillatory behavior. The customer can start with 10 to 100 Ohms and 10nF to 100nF and then vary these values as needed.
