Now we are using the ADP7159ACPZ-04-R7 for design, there are some question .
1.We want to use it to output 1.2V voltage,can it works?
2.If yes, is R1 a DNI? Can R2 choose any resistance value between 1k~200k?
Hi Getter,
Yes, you can use ADP7159-04 to output 1.2V.
R1 is DNI but you will need to short the REF & REF_SENSE pin, or use as 0-ohm resistor. R2 is negligible and will have no effect on VOUT.
Regards…
Hi Getter,
Yes this will work.
As a permanent solution, you can R546 (4.7kOhm) since you already shorted REF & REF_SENSE.
Bryan
Hi Getter,
Bryan
Hi Getter,
Bryan
My Schematic diagram below,Can it works to output 1.2V?
Hi Getter,
Yes this will work.
Bryan
