Several errors using DC1937B and DC590B eval boards for ltc3350
I'm trying to evaluate LTC3350. I bought the 2 above mentionned boards.
Following the documentation, I install ltcqev.exe. I set up JP1 on 3350 board and JP6 on DC590B.
When I plug the usb cable, I can see this error message:
while the mentionned file can be accessed with a browser...
The gui open. If I click on the start button for cap and esr measurement, I have another error:
Full message:
************** Texte de l'exception **************
System.FormatException: Le format de la chaîne d'entrée est incorrect.
à System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
à System.Convert.ToDouble(String value)
à LinearTechnology.DemoBoards.DC1937A.D3350.CheckStartCAPESR_CheckedChanged(Object sender, EventArgs e)
à System.Windows.Forms.CheckBox.OnCheckedChanged(EventArgs e)
à System.Windows.Forms.CheckBox.set_CheckState(CheckState value)
à System.Windows.Forms.CheckBox.OnClick(EventArgs e)
à System.Windows.Forms.CheckBox.OnMouseUp(MouseEventArgs mevent)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.ButtonBase.WndProc(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
mscorlib
Version de l'assembly : 4.0.0.0
Version Win32 : 4.8.4420.0 built by: NET48REL1LAST_C
CodeBase : file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
em3350
Version de l'assembly : 2.3.0.0
Version Win32 : 2.3.0.0
CodeBase : file:///C:/Program%20Files%20(x86)/LTC/LTC3350%20GUI/em3350.exe
Microsoft.VisualBasic
Version de l'assembly : 10.0.0.0
Version Win32 : 14.8.4084.0 built by: NET48REL1
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Version Win32 : 4.8.4360.0 built by: NET48REL1LAST_C
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Version Win32 : 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Version Win32 : 4.8.4400.0 built by: NET48REL1LAST_C
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Version Win32 : 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Version Win32 : 4.8.4084.0 built by: NET48REL1
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
DevComponents.DotNetBar2
Version de l'assembly : 11.7.0.4
Version Win32 : 11.7.0.4
CodeBase : file:///C:/Program%20Files%20(x86)/LTC/LTC3350%20GUI/DevComponents.DotNetBar2.DLL
Accessibility
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
mscorlib.resources
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/mscorlib.resources.dll
System.Windows.Forms.resources
CodeBase : file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
What should I do ?
configuration: W10 64.
Thanks
Julien
Removed useless information.
[edited by: JulienD at 9:04 AM (GMT -4) on 4 Nov 2021]
    on Nov 15, 2021 3:06 PM
    The first error is with the updater program. This is a separate program that checks to see if the GUI has been updated. This is a common error and I think the just select OK for this which must have done to get to the second error.
    The second error looks like a format error. I am not familiar with this error. It appears some number formats are not getting into the correct format for the program to use. Is it possible show the screen shots of the GUI prior to selecting the START button?
  • Hum, that was stupidier...
    I'm using aligator clips with plastic enclosure and the plastic part was touching the power test point instead of  the metal part....
    The message is not exactly what happened ;)
    Thanks
