For what reason is the ground plane of the LTC3130 disconnected from the input- and output-capacitors ground plane on the top layer? (see Picture)
LTC3130
Recommended for New Designs
The LTC3130/LTC3130-1 are high efficiency, low noise, 600mA buck-boost converters with wide VIN and VOUT ranges. For high efficiency operation at light...
Datasheet
LTC3130 on Analog.com
Hi Severin,
Based on my understanding, it is to separate the power ground plane from the signal ground plane.
You may read these app notes for additional reference:
AN136 - PCB Layout Considerations for Non-Isolated Switching Power Supplies (analog.com)
