The LT8641 datasheet defines a top power NMOS current limit and a bottom power NMOS current limit. The datasheet has a lot more details provided for the top power NMOS current limit which in the Electrical Characteristics table and how it changes with duty cycle and over temperature in the Typical Performance Characteristics section.
The bottom power NMOS current limit is defined only in the Electrical Characteristics table and its minimum value is lower than the minimum top power NMOS current limit in the same table. If the bottom power NMOS current limit is also a peak current limit, is there more information for how this changes with duty cycle and temperature? The concern I have is the bottom power NMOS current limit is the dominant term if it is smaller than the top power NMOS current limit.
