Hi
When using LT3999 with a light load, the output voltage became higher than the set value.
I also tried it with LTspice and I saw a similar waveform.
Is there a way to regulate the output voltage at light loads?
Best Regards,
Hgtk
Hi
Best Regards,
Hgtk
please check page 11. If you need a more stable Vout the use of a LDO might be necessary.
br
Markus
Hello Markus-san
Thank you for your quick reply.
I understand your answer but please let me know about the output voltage at light load.
I evaluated with almost the same circuit as datasheet sheet1 and found the following result.
Vin:12V
Vout:35V
Iout:no load
Fsw:500kHz
Turns ratio Np:Ns=1:1.08
The output of this circuit is calculated to be about 13V so this result is very high.
Are there any way to get an output voltage about 13V at no load condition?
Best Regards,
Hgtk
I would like to know the
the LT3999 is a push-pull stage where the Dutycycle is fixed and can only be modified with the RDC pin from the primary side. There is no feedback loop to accomodate for load/line variations from the output.
So you might 'attach' either a reistive load for operating at a default load as minimum load or use a zener on the output to limit the possible Vout increase.
The intended low noise applications are mainly Signalchains consisting of several opamps/ADCs which offer a decent amount of power consumption, hence your problem will not occur.
kind regards
Markus
Hello
Thank you for your reply.
I will try it.
Best Regards,
Hgtk
Hello Markus-san
I have an additional question about LT3999.
I am evaluating a ± output circuit and found a following large ringing waveform at SW pin.
CH1:10V/div
Fsw:500kHz
output current:50mA
I use almost the same circuit as below.
Would you please tell me the how to reduce this ringing?
Best Regards,
Hgtk
