Hi
Can you provide the PCB contraints for ADM1270 Hotswap controller IC since there is no information in datasheet regarding the PCB design guidelines. Can you also provide where we can find Layout guidelines for AD devices
Thanks
Abishek V
Hi
Thanks
Abishek V
Hi Abishek,
I will send a document directly to your email. The ADM1270 does not have many layout constraints, other than those common to high power distribution.
In general there is no single place to go to find layout guidelines for all Analog Devices chips, since these are as varied as the functions that can be provided, and the applications used. The best way to see how a particular circuit should be laid out is to look at the EVAL board files. The EVAL board shows our best thinking about how to design the circuit.
Thanks!
Nathan
