Make a variable power supply from 0 to 24 volt 1 amp using lt3942
I want to make a variable power supply using lt3942.  Can i vary the output volt using  Microcontroller+DAC instead of feedback resistor?    i should be able to vary volt from 0 to 24 volt in multi  step !           I need to measure the current in range of  nano amp to milli amp with bandwith of 100Hz.
