LT3083
Recommended for New Designs
The LT3083 is a 3A low dropout linear regulator that can be paralleled to increase output current or spread heat on surface mounted boards. Architected...
Datasheet
LT3083 on Analog.com
LTC3610
Production
The LTC3610 is a high efficiency, monolithic synchronous step-down DC/DC converter that can deliver up to 12A output current from a 4V to 24V (28V maximum...
Datasheet
LTC3610 on Analog.com
I have learned that a special hi-efficiency regulator circuit showed on Page 21 of datasheet.
In order to achieve my real demand, by search and pick, I find the monolithic buck IC, LT8648.
Now my question is, can a LT8648 buck replace the LTC3610 buck here in the picture with just a little circuit change?
Thank you all very much.
Highest Regards.
Jeronym Law
Hi Jeronym,
It should be fine to use LT8648 in place of LTC3610.
