LT3420 transformer phasing
Using the LT3420 with the Pulse PA0367A transformer
https://media.digikey.com/pdf/Data%20Sheets/Pulse%20PDFs/PA0367A.pdf
Should the connections be as follows:
PA0367A   LT3420
Pin 2          Pin 2 VBAT
Pin 3         Pin 6 SW
Pin 4         HV Out
Pin 1         Pin 7 SEC
Pavel
  • Hi Pavel,
    Sorry for late reply. You may have gotten answer separately from one of ADI FAE's. I will post answer here. So LT3420 is used on a flyback topology.  You need to be aware of the location of the transformer start of each windings indicated as dots in the schematic. In a way, please follow the typical schematic in datasheet. Pin 2 of transformer with dot should be to SW pin of LT3420. Correct on the secondary side: Pin 4 of transformer should be to the output diode of flyback or HV Out in your language. Thanks!
