Lt3680 works at 100 ℃ and 2A load. After working for a few minutes, it has no output and cannot be recovered. Where is its thermal protection function? Shouldn't it be able to recover after shutdown?
LT3680
Production
The LT3680 is an adjustable frequency (200kHz to 2.4MHz) monolithic buck switching regulator that accepts input voltages up to 36V. A high efficiency 95mÎ...
Datasheet
LT3680 on Analog.com
Thanks for application of LT3680.
Yes, it has the thermal protection. When the die temperature increases above the rising threshold value, the part would be shut down.
The part would be powered back on and be recovered after the temperature drops below the falling threshold value.
Andrew
