With regards to Multiphase LTM8051
Hi ,
I would like to know if i can use LTM8051 in the following configuration .
I would like to use every channel with clock shifted by 90 Degree.
If so please let me know how to use SYNC and CLKOUT pins on LTM8051 .
From data sheet we see when SYNC is powered by 2.4 - 4.2 V then it will working spread spectrum and clock will shifted with 90 Degree from channel 1/2 .
[the CLKOUT14/23 pin provides a waveform about 90 degrees out-of-phase with Channel 1/2 respectively] what does this mean .
Thanking you
With best regards
