Dear Sir,
Can I know that the relative for input voltage value V.S. output current? Do you have output current v.s. input voltage curve?
If out1 and out2 are positive voltage, these two output currents can up to how many current value?
Thanks.
Dear Sir,
Thanks.
The output current capability is limited by the switch current limit which varies with duty cycle and limited by die temperature. Factors that affect this are input voltage, output voltage and thermal environment. I recommend you simulate your exact conditions in LTspice to get IC power dissipation and then use the thermal resistance values found on page 2 of the datasheet to determine the max output current limit for your design.
