3W Emergency Light
May i know what types of ADI IC which can be used to act as a power monitoring IC. The details as below:
AC input cut off, battery will trigger the LED to turn on.
When AC available, the power monitoring IC will trigger the battery to  charging & always keep battery in full capacity.
The overall circuit no have intention to use MCU is it ok?
The attached file below is the overall circuit block diagram. So i do not know what kind of hardware solution can be use to act as power monitoring IC in this block diagram. Please advise? Thank you so much.
3WEmergencyLight1.ppt
