LTC3855 Differential Amplifier
Using LTC3855, I am going to design one channel to output 1V and the other to output 6.3V.
In order to use a differential amplifier, the Vout range must be 0.6V to 3.3V, and the data sheet states that it can output 0.6V to 12.5V when not in use.
I wonder if it can buck 1V on channel 1 with differential amplifier and 6.3V on channel 2 without differential amplifier.
Thanks.
  • Hello,
    Yes. The differential amplifier can be used to sense either VOUT1 or VOUT2 . This is mentioned in the pin descriptions for the DIFFP, DIFFN and DIFFOUT pins. The only limitation is that if a differential amplifier is used, then the maximum allowable VOUT is 3.3V.
    Mike
