lt3086 - voltage output regulation with digital potentiometer
I would like to use digipot to regulate output voltage in following circuit:
The regulation shall be allow the output from 0,4V -> 25V. Based on calculation, the resistance shall be from 0 to 0.5M. I can use the AD5293, but is has 100k max.
Is there any way to control output voltage with low voltage digipot?
Im thinking about:
Extend Low-Voltage Digipot Resolution to Control an Adjustable Regulator | Electronic Design
but the set pin compare the expects to have 50uA current. Is there any other way to regulate voltage with this chip?
It is a part of power supply provided from
Please advice how I can use digipot in above concept.
best regards
Maciek
Parents
    on Apr 14, 2021 6:07 AM
    Hi Maciek,
    You have to use multiple AD5293 in series to achieve 500K ohm resistance.
    If you want to use a low voltage digipot, then you have to use amplifiers as attenuator before digipot and amplifier after digipot to get the right set voltage.
  • Hi Vsethia,
    any example how to build attenuator? should it attenuate the input of the digipot as I understand. Lets make simple attenuator using 2 extra resistors 200k each connected to A and B. Having 100k digipot between these resistors, when output voltage will be 24V, we got ~5V between A and B of digipot. But it is not 5V measured to GND. In that case how to power the digipot?
    best regards
    M.
    on Apr 15, 2021 4:44 AM in reply to MaciekM
    You need an In-Amp at LT3086 Vout to GND with an voltage divider at the In-Amp input that will trim the LT3086 Vout to within the digipot terminal voltage range.
    Use the IN-Amp VOUT pin to connect to Digipot terminals followed by a second stage amplifier to meet the LT3086 SET and VOUT range requirements.
Reply
Children
