Telemetry Active 1% Duty Cycle in LTC4015
How to enable Telemetry Active 1% Duty Cycle in LTC4015 in Battery only mode? I want to monitor the ADC data in Battery only mode also. But Im worried about power dissipation if telemetry is active continuously . So Kindly provide the details how to enable Telemetry Active 1% Duty Cycle
    on Mar 30, 2021 9:31 PM
    This is something that you can do manually.
    In battery-only mode, telemetry will be disabled by default. You can then force it on, wait for it to be valid (MEAS_SYS_VALID, or you can use the alert), read the value you need, then turn it off. If you do this such that the telemetry is on 1% of the time, then you are operating at the 1% active duty cycle as described in the datasheet. So, the duty cycle is totally up to you.
